1 - 3 of 3 Posts
Howdo,
I have finally fitted a ST3 motor in my Superlight. She runs, took her for a few hundred yards no problems :D. Went to get my leathers on and go for a longer test ride and Error 1.2 came up :((-ve on the TPS, intermittent)
Any ideas what readings I should get on the pins or what could cause the problem?:confused:
Switching on the bike no errors everything is spot on.
NEXT: Fuel sensor. Have managed to get the sensor in the tank but no proper reading states empty. I think this could be due to the rubber connected to the bottom off the sensor being pushed tight on to the bottom off the tank (no flow) Should the wire on the sensor be at the top? Could i have the sensor upside down? Doh!
1 - 3 of 3 Posts
