For those of you who are not allergic to spreadsheets, I've created a calculator to help make the measurement, accounting, shim swapping, and verification steps a bit easier for a valve inspection and/or adjustment. I should point out that I use the in situ clearance checking method outlined in LT Snyder's book, ducatisuite.com, and likely elsewhere.
You can either nerd out like me and take a laptop into your work area, or you can print a sheet out and write the values down, then take them to a computer to fill out the spreadsheet. I've set the print area so that the whole table should print out onto 1 page for convenience.
The file is here: [url="http://redboston.com/duc/DesmoCalc_v3.xls"]http://redboston.com/duc/DesmoCalc_v3.xls[/url]
(Right-click and Save As...)
You need Microsoft Excel to use it. There are 3 sheets in the file (tabs at the bottom). I created it using a monitor set a resolution of 1024 x 768, so you may or may not have to scroll around to see everything on the sheets.
Sheet 1: EXPLANATION - describes how the calculator works.
Sheet 2: ST3-6k measure - the calculator that I set up for my ST3. You can modify it for your particular needs. Be sure to read the EXPLANATION page and heed the warnings found there.
Sheet 3: ST3-6k verification - the same as 2, but after assembling the engine, I'll put the verification measurements into this page.
I'll more than likely create new tabs for each valve inspection/adjustment as well as print hard copies for my records.
Please let me know if you find any errors in the calculator or any gibberish in the explanation.
