I have a few track days comming up and want to use my 748 that i purchased a few days ago, problem is i need to know if the valve clearance is ok? or will the engine blow up, they are on the loose side so i'm guessing that is good compared to too tight,
here are the specs
vertical: exh op .007 closing .004 intake op .005 closing .0045
op .008 closing .004 op .005 closing .0065
horizontal exh op .005 closing .001 intake op .0055 closing .0045
.006 closing .0055 op .0055 closing .0045
so what do you think.....
thanks for your help
here are the specs
