1 - 7 of 7 Posts
I am considering buying a used Termignoni system which includes the DP ECU.
Yesterday a dealer told me that the used ECU would not work on my 1098 because once an ECU is installed on a bike it cannot be used on another different bike.
Is this true?????
Thanks for the guidance.
Dave
Is this true?????
Dave
That is not true ! !!!!!!!
My question is this....
If I buy the used 1098 Termignoni system with the used ECU, will the used ECU work on my 1098 without re-programming????
If re-programming is required, is that the same as a re-map/re-flash (which costs $300 or so)?
YES all you need to do is reset the TPS and your good to go. NO REPROGRAMMING WHAT SO EVER.
TomTom is 100% correct.
1 - 7 of 7 Posts
