He's right but just make sure the bike has the upmap installed.
You know the upmap is installed when the ignition is activated and your screen posts either "Racing" or Racing EVO".Thanks for the replies - I appreciate the help ! As far as I understand there is no way to tell if the upmap was installed on my own ? I would have to ask the dealer to check ?
Take it to the dealer.... unfortunately they are the only ones able to install the upmap....and if the seller did not remove the upmap from their bike you will have a blank upmap keyI just acquired a used Termi full system with Upmap. Will the Upmap key still work on my bike? If not, can I get it reflashed so thst it does?
Thanks
It depends on the year. For later models, you have to use the dealer DDA device.Are you sure? From what I have seen online it is plug and play. Pretty sure the map is on the USB as kit was removed by dealer.
An anti privacy/no sharing thing.Are you sure? From what I have seen online it is plug and play. Pretty sure the map is on the USB as kit was removed by dealer.
