1 - 20 of 38 Posts
· Registered
I realize this is probably a wasted effort but I'm seriously thinking of removing the stock cans, and cutting the weld, removing most, or all of the baffles to try to get some volume out this exhaust. The aftermarket pipes that have proven good so far are Zards, and Termi's both are wallet busters. Until someone comes out with a Conti style replica pipe that looks good and has a reasonable price, I'm saying away from the 24K pipes. Has anyone given thought to this project? Are there any alternative ideas to mangling the stock pipes? If not I'll go ahead with my idea and post the results. There should be a Govt regulation against corking up this motor so it can't be heard a foot away at an idle.
Before I get flamed with "wanna play, gotta pay" I've just spent the last 12 months modding my car, I know what real HP, and all the good stuff costs. I just have a hard time justifying $2000.00+ for a little rumble that's already there, it just needs to be unleashed.
· Registered
Well, if I can finagle it this weekend, I will try and shoot some X-rays of the stock pipes so I can see their assembly without cutting them up. It might show that it would be easy to open them up, or it might show the only way is to go aftermarket.
· Registered
Hey Dug,
Do you have access to a parts breakdown of our bikes?? This would be invaluable! I know that some time must pass before the bootleg manuals come out and because our bikes are so new, I didn't think any such documentation existed. Unless of course you are a authorized Ducati dealer. I tried the dealer, and they are in the business of selling Termi's, so that was a dead end.
For Kels reply, yes I'll do it-- but I thought I'd ask if anyone has tried uncorking of the welded pipes first.
· Registered
wa6usa,
Here's the parts locator I think you are looking for:
http://www.ducati.com/bikes/service/parts/2006.jhtml?family=service&node=parts&modelName=2006p
As to uncorking the pipes, go for it. Take a look at the muffler core at the end-cap of the can. If you take a Dremel or other Die-Grinder and carefully cut the weld out of the back, I bet you can pull at least the center core out, if not the whole guts. Mufflers really are not rocket science to mess with. The trick is to cover up the surgery after it has been performed. If you are meticulous in your cutting, and can Tig or Mig weld, you should be able to put it back together, and worst case, have to dress the welds up a little. Regardless, powder-coating or heat paint will be in order to put a finish back on them. (They are made of stainless, so you could strip and polish them I imagine as well.) -Capt
· Registered
Discussion Starter · #6 ·
Capt.,
You are the Man! That was a great link, I didn't know that Ducati was so helpful with their support. Most companies keep these part numbers and parts breakdowns on DVD's or hard copy manuals. They are hard to get, and usually expensive. I've saved this to my hard drive, and you can bet I'll be using it for the life of the PS1000. My plan is to go ahead and cut the seem in the back with a dremmel tool as you suggested, and then pull the baffles. If I want, (or must) I will buy a pair of stock cans as they become available through this site, or ebay to have in reserve for the pending inspections in California. Unfortunately this stupid state has pending legislation to smog check, and verify noise requirements beginning with the 2006 model year. I really need to move, but my family has been here since the gold rush, and it's very hard to give up on your home state, no matter how ugly things are.
Northern Idaho is looking better every day. North Carolina would be ideal, but 3000 miles from the rest of the family might be to far.
Thanks again,
Tom
· Registered
Ya Ol' 49er...
Thomas,
You will be happy to know that my research has paid-off. The cables I purchased for the Converti-bars worked out real well. They are '05 MTS 1000DS throttle cables. Part #656.2.002.1A :D
Remember: these are for the 1000DS Multistrada, the other motor sizes for the Multi use single pull cables. You must use the push/pull set-up (2 cables).
They work out real well. They are plenty long, in fact they could be 2-3" shorter, but I re-routed them differently and they are fine. Now, the only thing limiting my clip-on position if the PS fairing and fairing supports.
I will probably update the Converti-bar thread too, for anyone interested.
-Glad the Parts locator worked out for you. Don't forget that if you need to use a part off another model (MTS Cables for example...) the Parts Locator provides the detail on all other models too! -Capt
· Registered
Discussion Starter · #9 ·
Hey Capt. You struck Gold!
That sounds like a huge help, I won't need pictures, only because I spend hours staring at the bike, and I can visualize what you did. I know the fairing is going to be very tough, I've almost resigned myself to taking it off for touring, and putting it on for local rides. As long as the convertibars give plenty of adjustment, I can see this being the only alternative to my varied riding needs. After all, the stock set up is good for 60 miles before I get off to stretch my legs. For the all day rides, I must bring the bars up to a comfortable seating position, so the upper half will come off. 6 screws I think.
That's the best solution I've got, other than buying a second bike for touring. Not!
The convertibars that were on ebay sold for $215.00, I hope they arrive as advertised. It's a big gamble just to save $85.00, however the fellow seemed like a straight shooter, so I'm sure on Wednesday I'll have the bars.
Also, I have the stock pipes removed, and I'm going to cut the cap on the rear tomorrow, pull some baffles out, and weld them back. Another gamble, only this time the stakes are higher.
Thanks again for the great info on the throttle cables, this is going to be a popular idea with PS1000, and Sportclassic owners.
· Registered
wa6usa,
I think you might be surprised once you put the Converti-bars on. The lift is not going to be quite as important as bringing the bar back toward the rider as I have said before. You will be very happy I think with the difference in feel and comfort once the bars are another 3/4" higher, BUT back about 2". It will change your body geometry substantially. Rather than being somewhat "raked" over the tank, you will now be more upright.
When your torso is in a more upright position, the wheel base of the bike will feel about 3" shorter, the bike feels lighter (...yet...) and it will feel as though you can run tighter in the corners, and be much more relaxed during a brisk ride. -Capt
· Registered
Discussion Starter · #13 ·
Yeh Capt. I see what you mean. The substantially forward position makes the rider (me) feel like my nose is further forward than the front wheel. I'm looking forward to the convertibars, and the new throttle cables. (they are on order first thing in the morning at Pro Italia)
It's hard to imagine being lighter, and quicker through the corners :) When the PS 1000 is set up properly, which mine is, it feels like a GP bike. Without the 250 HP engine that they have, but the ride is on rails. The fellows at Pro Italia rode my bike, and told me I was close with the set up, but I finished it with 5 clockwise clicks on the front Ohlins. Now it's really just perfect in the corners, and the engine has enough torque to pull me out and get me going again.
Just waiting on Brown Wednesday, and the stock pies to be cored tomorrow.
· Registered
Discussion Starter · #19 ·
Well after 2 fast and furious days of poking around and surveying the pipes, I've come to the conclusion that it can't be done. I'm not one to give up easily but this design has me stumped. 1st - the cans are double wall construction, that's why the outside never gets very hot, and the paint stays fresh looking. 2nd- I'm sure that I will have to cut BOTH ends to get some of the baffles out. 3rd- all of that effort seems like it won't be fruitful or wise if I ever plan to keep the cans looking anything like the stock appearance. They will get mangled in the process of doing this.
I guess our pals in Bologna knew that anyone with performance, and sound on their mind wouldn't mind forking over a kilobuck or two for that elusive roar. It certainly has me bummed, I would rather spend $3000 on a supercharger for my car to boost it up to 500+ HP than spend almost $2000 for a 2 into 1 Termi that might get me 8HP. This is ridiculous. I hope the aftermarket guys put their production facilities in high gear for the Sportclassic line, I think Ducati/Termi has way to much greed going on.
· Registered
Bummer... $2000 is definitely pricey especially when you compare it to what a big Ford F250 Diesel aftermarket exhaust costs... (read: 1/3-1/2 the cost) or even a Tubi Ferrari exhaust... very odd...
Thanks for lookin' into it...
1 - 20 of 38 Posts
