Need your ideas. I bought an industrial scissor lift to use it as a motorcycle table lift. But the thing is covered with the stickyest grease I have ever seen. Anti rust treatment maybe? Well it is very VERY hard to remove.
Forget the brake cleaner, industrial degreaser like simple green, dunk, varsol, engine cleaner, nothing have any effect. Even tried to soften the stuff using a torch, doesn't change a thing.
What's working is using a scrapper first, that remove maybe 1/8th of goo, then dunk and brake cleaner for the rest but with a lot of work, and towels. It's really time consuming so there must be a better way.
What's next? Considering renting an industrial vapor cleaning machine. Will this work? Any other (better) ideas?
Thanks
Thanks
