1 - 2 of 2 Posts
UK Pro POV 20 GoPro Camera Storage Case
$44.99
The new camera protector from UK Pro is specially designed to keep your GoPro camera and accessories together and organized in one compact protective case. Go ahead and take it anywhere you take your gear. It's waterproof, dustproof, and shockproof.
Designed to protect cameras and accessories
Specifically cut insert for GoPro HD Hero 2 and HD Hero Cameras
High impact ABS and stainless steel construction
Protects against shock, dust and water (5m Depth)
Patented pressure equalizer ensures easy opening
Custom designed inserts organize and protect sensitive equipment
Size 7.7 inches X 4.7 Inches X 4.0 Inches
Weight 0.9 lbs
Proudly made in the USA
Includes:
Custom ABS resin case with stainless steel hinge pins and latch assembly
UK Pro patented “equalizer” latch assembly
Two custom insert compartments; upper compartment for camera, camera housing, SD cards and a lower compartment for your various accessories
Standard one-color protective inserts
UK Pro POV 30 GoPro Camera Storage Case
$54.99
Weight 0.9 lbs
Includes:
Premium two-tone protective inserts
Nylon strap with carabiner
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
That looks really nice. May ask for one for Christmas (next time I will be in the US). everything now just sits in the original boxes in one way or another!
1 - 2 of 2 Posts
