Spot on!You have to keep on until you find it or you are certain it is outside.
From what you say its not very clear what part you mean, can you please explain again?
You mean you opened the front cyl cover and then went to undo the stack?
Then the airbox is still in place and the piece should be in the airbox, no?
I cant make ends meet.
the trumpets are held in by two little arms. you rotate the trumpet and these two arms lock over two bumps that stick out on the trumpet. one of these arms broke off and fell somewhere. they are under the airbox not in it. i have looked everywhere inside that valve cover but haven't taken the camshaft out or anything yet. I agree that I have to find it but I am just looking at options and trying to get opinions. I have not taken apart a desmo engine before and I don't know where that piece could make its way to. I imagine that camshaft area is pretty enclosed other than a few oil galleys maybe. I can't see it going anywhere except the bottom of that camshaft area and resting against one of the red valve seals perhaps. Any thoughts after that description anyone?You have to keep on until you find it or you are certain it is outside.
I cant make ends meet. Is it just the thin plate that holds the stack in place? Then its magnetic, if its the stack, then its alu.
uggggghh god you are giving me chills. I don't think it went down there. The throttle bodies were still on and closed obviously. That was one of the first things I checked. Ill check again but I know it isn't there thank god. I will make a run to the auto parts store and get one today. I am also going to scour the garage floor like a rat sniffing for even the slightest lick of cheese.Ive done it so many times Im sick of it
How about it went down the intake? Use a good flashlight and see if the intake valves are closed or not.
On the front cylinder you cannot see directly so you need a mirror.
First get the magnetic pen suggested and fish for it, I would.
Doing valve lash on a 996 is interesting at best and such pen is the shit!
Anyhow get the magnetic pen, its 2 bucks and it can save you soooo much trouble.
By trumpet he means velocity stack.
Those metal tabs are steal best I can tell so a magnet should snag it.
Im curious though reading back through your original post and some others here, did you take the intake side valve inspection cover off with the airbox still on? I guess the forward tab is what broke and you think it may have tumbled down the leading edge of the intake manifold and into the head?
If thats right and you cant see it, best to pull the head then and dig though it till you do. Better safe then sorry.
To start off with, working on one of these early Desmo 4-valve heads isn't that difficult. Even if you wound up having to pull both cylinder heads to repair the 'trumpet' (no clue?), it's doable. Most people freak out about not wanting to deal with the timing belts. You're already in the mindset of doing that. Also, my 2-cents says that if you want to check your valve clearance correctly, the heads are off to where you can take your time. Did this for the first time with my 851 (am thinking the 996 is very similar in design)a few years ago. See if you know someone who can lend you the DesmoTimes' workshop manual. Very easy to follow. In closing, I hope I didn't take this thread 180 degrees in the wrong direction.....Again, just seemed like you were starting to freak out a bit...... Good luck and relax.
Pat
PS: have you ever inspected your rockers for chrome-flaking like one of the other posts is talking about? Pretty sure "some" batches of 996s had problems with this...
Pat
I voting for it being missing before you got to it, but better safe than sorry.
Check your clothes, especially if you wear pants with a leg cuff.
Also, check the shoes you wore to be sure the tabs not stuck around the shoes laces.
I'm in aircraft maint., and everything has to be accounted for.
So, good luck witht he adventure and recently I dropped a nut in the shop while working on one of my CBX's. I later found it 15 feet away from where it was dropped a foot to the floor.
Later, George in Delaware
