1 - 12 of 12 Posts
I have a 2006 Sport 1000 with only 6800 km . The tyres still have plenty of tread but I have heard that as they are seven years old they will have lost some of their softness with a resultant reduction in grip and should be replaced . I would appreciate any advice from forum members. I am not a particularly hard rider but any significant reduction of grip / safety-margin does worry me .
Come in Spinner :)
Have a look on the side of the tyre, they have a manufactured date on them..it's a small oval with 4 numbers in it.
The first two represent the week of manufacture (01 to 52) and the second two the actual year.
They might be even older than you think they are.
As long as there are no obvious signs of damage or side wall cracking, you should be okay after using them for a bit. :)
I replaced my seven-year-old Michelin PR2s because of age, which is in accordance with many recommendations: Unsafe Motorcycles: Motorcycle Tires: Age Matters
The Pirelli Angel ST have been a good replacement, although I might go back to Michelin next time. Be that as it may, it's cheaper to replace your tires than deal with the consequences of tire failure.
Just my 2¢.
Ron
Just my 2¢.
Ron
+1 good advice
Temporary greeter
I would think that with 6800 km on them they are about done anyway.
Treat yourself to a new set and the bike will feel like new again. Every time I have ever tried to stretch the life out of a set of tires I kick myself for not doing it sooner as the new ones feel so good.
Food for thought.
Get new tires, our bikes parts are too expensive to risk even a goofy low speed incident. Our butts are worth too much to risk a high speed one.
I believe that you got your money's worth out of your existing tires at 6800km.
Just my opinion, but I would recommend new tires.
Discussion Starter · #9 ·
Appreciated
Thanks for the advice everybody. It looks like I will be getting new tyres now. It makes you wonder how many older bikes out there are being ridden around with old tyres that may not be up to handling an emergency braking or turning situation.
I would say to always replace the tires in pairs as well, even though only the rear tire is worn out.
Temporary greeter
Excellent choice!
just stumbled across this post. I just bought a 2006 Multi last week that had been sitting for a while. Before I rode it I changed all fluids, checked connections, adjusted the suspension... then I rode it. Tires looked great but felt like something Fred Flintstone would have used. Checked the code, tires were early '06. New PR3s will be here tomorrow.
1 - 12 of 12 Posts
