Hi all,
I'm new to the forum. I have just installed Tuneboy software on my 2014 Multistrada Pikes Peak. I used a laptop running Windows 7 home premium. The install went well and 3 tunes that were supplied were loaded. I have a QD exhaust with cats and DB killers. The bike runs OK but I need to get it Dyno'd just to check that the tunes are not too far off.
My problem arises that when I run the Tuneboy Trim edit program the PC displays that the map has been read from the ecu but when I start the bike I get no engine data. That is to say that the cursor on the map stays in the bottom left hand side of the screen. No RPM or TP is displayed. It just doesn't work with the bike running, so I am unable to get the bike checked on a Dyno.
Several emails to Tuneboy support but no replies.
The software is Mitsubishi Flash V6.
Has anyone else had this problem? Can you suggest a fix.
Any ideas would be appreciated.
Thanks
Brad
Thanks
Brad
