1 - 10 of 10 Posts
anyone ever put a tube in a tubeless tire? or know of a reason that it should not be done? i want to do it on a 1965 ducati mountaineer. top speed is about 45 mph so speed issues should be nil. the bike weighs about 150 pounds which is also about what i weigh. so total weight is about 300 pounds.
I see no issue. Sport Classic spoked rims require tubes and come with "regular" "tubless" radials as I understand it.
Dual sport guys with spoke wheels do it all the time to run street tires (I do).
Adds a lot of weight, and you're guaranteed to get a pinch flat or two on the rear the first time you try to mount it.
Use new tubes and a lot of talcum powder. And band-aids for your knuckles, you'll need them.
If you've got the technique down, say from riding dirtbikes, you won't pinch them. Make sure the tube isn't stuck under the bead of the tire before you air them up.
Discussion Starter #8
I will probably give it a shot. If I lose my patience or start popping tubes I can run it up to the local shop and pay them $20 to do it right. :)
Pretty much any of my older bikes in my signature are running tubeless tires, with tubes on them because the wheels wouldn't keep a tubeless tire on the bead...or air in the tire for that matter on spoked wheels lol...it's normal practice.
add a few psi to the tube, just enough to give it shape, i helps keep the tube from getting pinched during the install of the last side.
1 - 10 of 10 Posts
