I’m having problems turning on my Scrambler (out of warranty). Turning on the ignition key... the headlight led flashes once but turns off and dash doesn’t come on. I checked the main fuses by the starter relay (2x 30amp fuses) and they seem fine (not blown). I’ve also checked the fuses under the fuse box and all seem fine (not blown). I also checked the battery and its holding a steady 12-13 volts (on a battery tender). I’ve also checked and swapped an ignition key switch with a newer one and that didn’t solve the problem. Using a multimeter I checked to see continuity with all the leads from the ignition, starter relay, fuses, grounds to engine; to remove any hint of a possible kink in the wire -nothing nada...
If its not the battery, fuses, grounding and starter relay issue... then what could be the problem?
