1 - 6 of 6 Posts
Who's taken theirs to the track? What tires did you use? Any recommendations? I'm thinking of using up the stock ones but I want to have another set ready to go.
I did Sears Pt a few weeks back on the oem Diablo Corsa III tires and was very impressed with how they held up - even in 100* temps.
The tires had enough grip to grind down the edges of both pegs.
Cool, thanks. How did the tire look afterwards. Would it last two track days and a 1 hr drive home, IYO?
Yes you will have no issue doing two trackdays and the ride home on the Diablo Corsa III tires. Here are some pics of the two tires I used a few weeks ago....
Diablo Corsa III - roughly 140 track and 600 street miles. 1:54 pace at Sears Pt. Plenty of center and edge tread remaining.
StreetFighter S
Diablo Supercorsa - roughly 360 track miles. 1:50 pace at Sears Pt. Plenty of center tread but down to wear bars at edge.
1098S
StreetFighter S
1098S
Excellent, thank you! So the Streetfighter is 4 seconds down on the 1098 for you? What is the limiting factor for you on the SF? Do the different tires make a big difference? Are those the DOT race supercorsa's or OEM SP's?
1098 has a slipper clutch and the front end is more planted than the sf. But I think the biggest factor is the peg clearance and the heatshield getting in the way of my right foot. Put higher rearsets and with more seat time I bet the delta will be within a second or two.
Have fun at your trackday and be sure to post pics and your track impressions of the sf!
1 - 6 of 6 Posts
