Anyone ever mounted a TPS to a Mikuni BDST38 (SS900)?
I'm planning to install a Ignitech and since this unit is compatible with a TPS sensor I was wondering if such a sensor can be mounted.
I searched the internet but I can't find anyone who did this. I found some brackets to fit on a Keihin but none for Mikuni.
I did find a guy who did this on a MZ with a different type Mikuni but that's it...
Making any kind of bracket isn't the problem. I know some technical guys at work who can make me any bracket I should need. :grin2:
But that's it... :frown2:
The carbs have some moving parts (the 'ring' where the throttle cables are attached to is the obvious first choice) and there is the part circled in red in the attached picture. Anyone know what's behind this cap? I assume it's the end of the butterfly-valve rod. But I can't get the cap off and I'm afraid to ruin something if I use brute force. Anyone ever removed this cap?
So, any kind of information is welcome.
Did you ever mounted one?
Know any websites with useful info? Best sensors? 12v to 5v converters? Wiring? A thread on Ducati.ms concerning this issue?
Thanks all!!
Thanks all!!
