1 - 20 of 32 Posts
· Registered
If you wife is on the back then there'll be little space for a tail pack also, so you might want to consider a Ducati topbox or a givi one?
Ducati ST2, ST4, ST4S. GivI Rack and GivI Top Box | eBay
The DP tank bag an protector is good but hard to find now.
Bagster do one which is still available, then u can chose the baglux bag you want to go with it.
Bagster Tank Cover DUCATI ST2/ST3/ST4 2000-2002 YELLOW/ANTHR.. - Motorbikes and Parts - Givi / Kappa Motorcycle Luggage Specialists - bagster-tank-cover-ducati-st2st3st4-20002002-yellowanthracit-p-12831.html
· Registered
I used a double expanding Chase Harper tank bag on my trip and as i had no passenger i used a Twisted Throttle bag set sideways on the back seat.
TwistedThrottle.com : DrySpec™ D28 Dual-End motorcycle dry bag & D38 Rigid motorcycle dry bag by Twisted Throttle
I choose to get the bag set for the rear but only used the ridged bottom bag except one day i had the D28 roll on top with dirty clothes before hitting the laundry Matt.
I've seen others with two D28 on top on the hard bags but not seen it with passenger yet...
· Premium Member
Tour pak sounds so Harley like...
What ever works is good I have seen guys with a hundred Bungee cords .
Good luck lots to choose from..
· Registered
Ventura Rack! We like ours.
Do not use bungee cords, those suckers can pert near put an eye out. There more dangerous than anything I've seen in the logging woods.;)
· Registered
update on Ventura rack system. I picked up the new to me st4s that had
the stock side cases. I wasn't sure I could fit the Ventura up with those.
Tonight I moved the ventura rack over from my old ST4 to the new ST4s.
Works perfectly with the non-fango racks on top of the ventura L brackets.
· Premium Member
Anybody know where I can find the Ventura L-brackets used?
I found the pack rack and bag at a BMW flea market at a super price and with all this good talk about the Ventura system want to give it a try.
· Registered
1 - 20 of 32 Posts
