Can someone with a service manual tell me what is the torque value for the oil drain plug and the oil filter?
Thanks
Thanks
Some common torque values for a 97 900ss:
Oil drain – 31 ft/lbs
Oil screen – 31 ft/lbs
Oil filter – 8 ft/lbs
Front caliper bolts – 32 ft/lbs
Rear caliper Bolts – 18.4 ft/lbs
Front wheel nut – 46 ft/lbs
Front pinch bolts – 15 ft/lbs
Rear wheel nut – 51.6 ft/lbs
Shock bolt - 27.3 ft/lbs or 37 Nm
Swingarm pinch bolts – 27.3 – 36.9 ft/lbs (37-50 Nm), mine are set at 32.47 ft/lbs (44 Nm)
Cam belt tensioner bolts – 19 ft/lbs
which engine?
1000ds:
Oil drain plug: 42Nm min. 38 max 46
Oil filter: 11Nm min. 10 max 12
Sorry it's metric but thats how it is in the manual.
