1 - 3 of 3 Posts
Just got my SFS, and they put the inspection sticker on a plate that covers the caliper and uses one of the caliper bolts. I believe the torque spec calls for 43 nm and grease? If the spec is correct what type of grease? Also the oil drain plug spec is 20 nm and the sump bolts at 14 nm? Thanks in advance for your help!
1 - 3 of 3 Posts
