I am planning on buying a service manual, but I'm also planning on installing my frame sliders tomorrow before I get a chance to get a manual from the dealer.
So in the meantime, my question is can anyone tell me what the torque specs are for the engine/frame/slider bolt?
Thanks in advance,
Jeremy
Somewhat. I'd have to check if the Diameter and pitch are noted anywhere on the package. Also, it does say not to supercede the manufacturers recommended torque settings.
Thank you for the link though! That'll be a good reference point if I can't find the factory settings.
The frame to engine bolts are 60Nm or 44ft.lbs.
Reactions: stormbytes
Bingo! Thank you, that's correct. I actually called the dealership and asked a tech since I jumped in before anyone could answer. Just like you said, 60 Nm/ 44 lb.ft
