1 - 3 of 3 Posts
I had the forks off this winter and am putting them back on now but I can't find the torque settings. Does anyone have the values for:
Upper triple clamp fork pinch bolts
Lower triple clamp fork pinch bolts
Steering Stem clamp bolt (the one behind the pin bolt)
Thanks
Excel Addict
2001 900SSie
900SSie 2001 fork torques
This is from the PDF manual I have - tried to scan but it is too faint to read.
This is the terminology in the manual for fork related bits.
Steering tube fastening screw M20 x 1.5 12Nm
Steering heads screws for forks legs fixing M10 x 1.5 37Nm
Steering head screw for pin fixing M8 x 1.25 23Nm
Bottom yoke screw M8 x 1.25 20Nm
Thank you Punch. It is finally warm enough here to get things put back together.
Joe
1 - 3 of 3 Posts
