Hey fellas!
I'm in the middle of taking off the clip ons on my SFS and I could use some wisdom from whomever has done it, I like to slip the top triple off the forks from the top but I'm seeing nothing but trouble unless there's a easy way that I can't see. The first time I took it off when I painted the frame everything came off so that doesn't count, the time I mounted the clip ons not too long ago I slid the forks down by hanging the bike from a rafter.
This time if possible, I would like to take the darn thing off from the top, the way I think should be possible without dismantling the whole bike. The problem is that the steering lock neck is tapered so when I lift the triple it stops against the other tapered side of the lock. Of course I took the 2 posts that hold the ignition off but the whole unit I believe is held by a bolt from down under where I can't get to, is there any other way that I'm not seeing or that's the only way?
Thanks for any imput.
