All
I am installing some new CycleCat clipons on my CR. Hit a bump in the road with the triple clamp. The ignition switch is attached to the triple but there are some weird cone shaped bolts attaching it with female threaded holes but no visible hex or bolt for unscrewing. Haynes nor the shop manual address how to remove the ignition switch, and I don't think I have enough slack in the wire harness to pull the triple over the forks. Anyone with experience on this?
Thanks!
Thanks!
