1 - 20 of 41 Posts
I have 3 different bikes that need tires this year. I was curious how many riders change their own tires and which tire machine/bead breaker do people like best?
I use a NoMar older model. I think it was about $700 for all of the attachments and accessories. It is a bit pricey upfront but the convenience factor is huge. I do my 5 bikes at my leisure and can do trackday flips and swaps between sessions. I also do several of my friends bikes as well (for beer :) )
t_bare
Reactions: Buhgaboo
I used to do them myself, but it was always such a hassle that I'm perfectly content paying someone to do them from now on. If you are going to do it, definitely go for good equipment. Get those spoons that Buhgaboo has, they look way better than anything I ever used, which was a large part of my frustration.
I was curious how many riders change their own tires and which tire machine/bead breaker...?
I do.
Harbor Freight changer(s), Motion Pro 15" irons and rim protectors. Several sets of motorcycle tires and a few more sets of car/truck tires.
$120 dollars to swap two set of (bike) wheels/tires was the last straw for me. That was with me carrying them in/out. Got the entire 'kit' for less than $100 buy finding everything on sale and have probably saved near to $600 beyond that since. And, I know it's done right.
A Nomar setup would be great (undeniably) but, I don't do enough to part with that kind of coin.
https://www.harborfreight.com/manual-tire-changer-69686.html
https://www.harborfreight.com/Motorcycle-Tire-Changer-Attachment-60810.html
I used to pay professionals to do it. Last time I payed for it, they scratched my rims badly. So now I do my own tire changes.
I'm using this bead breaker from Biltema (comparable to Harbor Freight here in Norway).
Dekkverktøy - MC-tilbehør - Biltema
3x tire spoons at 350mm
Dekkspak - Biltema
A bucked of tire lube and rim protectors.
Take your time, go slowly. Use your brain, not your muscles.
I would love a tire changer thingy but I can't mount it to anything where I'm at. Trickiest part is getting the tire to sit into the rim...I'm always tearing the tire on the last little bit, still seals but geeesh so sketchy some times...
Sent from my Pixel XL using Tapatalk
Discussion Starter · #9 ·
I use the No Mar tire changer. Super simple. No scratches (just like the name says).
So I looked up the No-Mar machine and saw a variety of different prices. Are there different models?
And what about balancing? I think I've seen mention of a Parnes balancer? Not sure if that is the right name. I don't mind investing money in high-quality tools, I just want to make sure I am looking at the appropriate ones.
Balancing doesn't really require anything special. Unless you are racing and want absolute precision, you can balance just by spinning the wheel on jack stands or the like and paying attention to where it stops. Balance opposite the heavy spot.
Tearing the tire and marking up wheels are two of the biggest reasons I hate doing it anymore.
I use a NoMar also. I got mine at Laguna Seca one year. Show special....I think I paid $499 for it. Shipped to my house too. Best investment in my garage I've ever made besides my welders.
It just makes doing tires so much easier. I have multiple bikes to take care of, so inevitably, at least one, sometimes two need new tires in the course of a year. I can take care of my own plus my riding buddies. I do others too, for beers.
I use a Harbor Freight special for a balancer. I paid less than $40 for it, and it is not discernibly different to any of the others I've seen around the interwebz. I use K&L stick on weights that I got through Cycle Gear. I've had a box of weights now for at least 4 years and I'm not going to run out anytime soon.....sean
I bought the "big kit" It came with a lot of stuff, important stuff like the stuff you need to balance a wheel from a single sided swing arm :)
t_bare
You guys gotta lube up!
Warm hooker spit is best but very expensive...
Do the shops balance the wheels properly???
Oh Sure we do, the wheel just turns out to be a perfect balance so no weights needed....
I am suspect...
Don't cha hate it when there are too many weights?
And the new kid at the shop is the tire changer grunting away with your beautifull expensive rims...
See above post
Super Moderator
I use the Marc Parnes balancer too. Great little tool. I'll support the ends with jack stands or buckets.
Of course, some would say dynabeads are the way to go for tire balancing. But that's a whole 'nuther thread. :wink2:
Beads for me. Never going back to stick on weights, unless I am planning on track time. I have read the beads can be an issue with track tires. Something about the inner liner and the heat generated causing them to clump up with rubber. No idea if true, but...
Street? They are wonderful.
I do change my own tires. I use a simple table top deal with a bead breaker, rim protectors and tire irons. A little muscle needed, but not too bad and it's an every other year thing for me with two bike to wear out.
I use this.
Reactions: Wolverine1
t_bare
When I bought mine, I had no need of stuff for balancing a wheel from a single sided swing arm. I didn't have a 996 to worry about back then. Now I do, but I've plenty of time to order a set......the 996 won't need tires for at least a season.
Absolutely do. Not just on my bikes either. However, having worked in a shop changing tires I can say with certainty, quality tires (and tubes) make a big difference in how many weights are required.
I had numerous customers opt for cheap tubes and there was enough of a heavy spot that those rims required more than the usual weight to balance. Then I had one customer who would not buy any tubes save for Michelin. His Sport 1000 rear wheel was so sweet on the balance machine, I need a single weight to get it perfect.
I loved mounting Michelin tires for customers. I couldn't tell how many I did that simply balanced with no weights at all. Probably 75-80% of them. Bridgestone by comparison was the next in line for fewest weights needed, and I probably found 30-40% of the ones I mounted needed no weights at all.
I won't get into beads. I hate them. I didn't like demounting a wheel that had them "installed" as the once the bead broke, tire beads went everywhere. I didn't like installing them, it was a mess to do. Almost always ended up spilling them all over the shop floor.
Yep. Happens on street tires too. Kinda like a zilion little snowballs rolling around inside your tire. After a while some begin to "grow" rubber on them, and they skive the rubber off the inside of the tire too. So there is a ton of rubber debris rolling around along with the beads.
I was asked several times to reuse the beads. Forget that. I'd gather as much of the mess of rubber and beads as I could, and put it in a plastic bag for the customer. If they wanna reuse them, be my guest. I'm not spending an hour separating the beads from old rubber to "reinstall" them in a tire.
Water would be less of a head ache and do the same thing. It's also free........sean
Some tires are more of a pita. Bridgestones have very very stiff carcasses. My VTR loves them but spooning them on was a struggle. Michelin is the opposite and very easy. Sitting them in the sunlight helps as well.
I was in the same boat. Last time pizzed me off so much. I looked at the guy and said, "ya know you scratched the hell outta my wheel?" He looked back and told me it was like that when I brought it in. :mad: I said bullshit and told him word of mouth travels fast.
Ended up spooning my own for years, till I got a job working on bikes. Machine for me from now on AND I remember that experience and treat every wheel like it's my own.
Beads work, they are in the rear wheel of my Multi now.
I've seen very old ones and have reused em too. Just please don't throw the bag in there (yes they have). Main deal w/ beads is to be very cautious with bead lube. Can't allow any moisture in there with them. No experience w/ race stuff...
I am suspect...
Ya know... I've found it happens quite a lot. I'm a tech at a used sportbike shop (not a dealership) and we have a computer balancer. Some tires are better than others, Michelin being one. They do not mark a valve stem spot and quite frequently if the wheel is balanced the tire doesn't require me to move weights. (I'm @ about 120 tires on the season so far)
Discussion Starter · #20 ·
So I ordered one of the No-Mar Classic tire changes and also a set of Dunlop Q3s for my Streetfighter. Will let the group here know how well things move along once I get the machine and the tires. Appreciate all the feedback!
1 - 20 of 41 Posts
