Currently putting a DS1000 engine into a 900 frame.
I noticed that when the timing marks on the cam pulleys and the scribed mark
on the clutch case are aligned, the pointer in the timing window ( left side) doesn't line up with the TDC mark
on the rotor and the front piston comes up short by nearly 9 degrees of crank rotation.
is the timing mark on the layshaft pulley out or do the cam pulley timing marks not align with TDC?
thanks Brad
I learned something today
the mark on the timing pulley is an indicator of timing shaft position. it's not a tdc mark of any accuracy.
Sorry I dug up an old thread but... Phew! I’m just about to check my valve clearances and found that the TDC reference marks on the cam belt pulleys did not co-inside with any of the “TDC” marks in the timing window. Had me confused/slightly worried. On with the job then...
Further to above, after checking again more closely, my timing window TDC marks did sync up with the pulley marks.
