Just got done replacing my belts on my Hyper 1100EVO.
Followed the CA Cycleworks Videos, everything went fine.
But after I set the tension on the belts, I noticed that my marks on my belts no longer matched up with the markings I made on the belt covers and casing when the horizontal cylinder is TDC. Is that normal??
Got the bike on a rear stand and rotating the rear wheel while the bike is in 6th gear.
Last thing I did was rotate the rear wheel backwards 90 degrees to get the vertical cylinder TDC which is what the CA Cycleworks video says to do. Was I supposed to go 270 degrees forward to get the vertical cylinder TDC?? Thats all I can think of.
Here's a pic of the front cylinder at TDC.
