1 - 3 of 3 Posts
I have replaced timing belts many many times and there was always room in the adjusters to take up the slack with a 5mm spaced wedged between the idler roller and the belt.
I have just fitted new belts from Exactfit. They were tight when first fitted but after I started up the engine there was so much slack that the adjusters are at their max.
Has anyone else had this stretch problem with Exactfit belts?
Retired Pipe Polisher C2H6O+
Two things. Did you directly compare the new and old belts for length and are you sure you rotated the tensioner the right direction?
Edit. Forget the second question. I don't think that's possible on the 2v motor. :)
+1
Take the new belt off and check it against the old one for growth, etc
1 - 3 of 3 Posts
