got that, thank you though, on my way to check to make sure all hoses, wires and everything goes to right spot. wish me luck!Ground wire from ECU? Ensure it is attached to battery box bolt on left side. Not to battery negative post.
Thanks Mike! Short of buying a new battery how can I test these theories? I ran a multi on the battery yesterday and it was showing 12.76. Well, that was without a load on it. When it is cranking an slowing like that the light on the dash as well as the headlight is flickering on and off. Not sure if that tells anything or not...thanks again!It's cranking weak. Either a bad battery or not fully charged or there is too much resistance between the battery and starter.
Judging from the way the cranking slowed down at the end I would lean towards a bad battery or not fully charged. It should crank much longer and with more gusto. The ECU needs a certain minimum voltage to work and a weak battery's voltage will drop too much to operate the ECU.
Can you run jump leads from a car battery ?Thanks Mike! Short of buying a new battery how can I test these theories? I ran a multi on the battery yesterday and it was showing 12.76. Well, that was without a load on it. When it is cranking an slowing like that the light on the dash as well as the headlight is flickering on and off. Not sure if that tells anything or not...thanks again!
yeah but they've all been spinning, they are all the same number of notches from marks on the case. count back from each mark and then the mark on the cam wheel shows up. am i wrong in my thinking here?What the heck???? Your marks aren't lined up at all. The marks on the case should line up to the marks on the cam gears. I have no idea what you're lining them up to. Hope your motor is OK.
Why aren't you lining them up to the marks on the case instead of counting notches? Take them belts off and line those puppies up.yeah but they've all been spinning, they are all the same number of notches from marks on the case. count back from each mark and then the mark on the cam wheel shows up. am i wrong in my thinking here?
if i put the engine turning tool back in and "spin the wheel" five notches they will all line up. no?
