1 - 7 of 7 Posts
OK, guys......how the hell do you remove the vert belt cover. According to the manual, there is a bolt @ about 8 o'clk, directly behind the rear sub-frame. How do u get to it?
Discussion Starter #2
Got it! Im now stuck, as I dont have a plug socket to get the plugs out. Snap On man will have one. Belts dont seem that tight....
You get at it with a long Allen key through the small hole in the alloy frame plate that must have been put there for that purpose.
I was also surprised at how loose the belts felt. But hey, if it ain't broke....
Discussion Starter #7
My belts felt loose. Really surprised and be interested to see if they are at the correct tension, or.....I will continue workin on her Thursday.
1 - 7 of 7 Posts
