I use green locktite on the old nutHas anyone tried a stover instead of a fujilock nut for this application. Seams like the nuts are not easy to get at least where I live.
From what I've been reading...the Stover nut will deform the threads of the stud over time...either nut should be single use ideally, both loose something like 50% of their retaining power after their first use...so in short, it will hold but it will also deform the stud slightly...that said I've done over a dozen belt removals on my monster on the same Fuji nut + green locktite...just be sure you let it setup over nite.Has anyone tried a stover instead of a fujilock nut for this application. Seams like the nuts are not easy to get at least where I live.
