I spoke with Josh of IMA USA last week, and had a set of 848 adjustable triple clamps in my hands two days later. Here's the details:
IMA USA does exist, and even though I have had faster responses from dead people, once you get their attention, they really deliver. Josh happened to have a set of 848 adj triples that combined the regular MOD4-5 set with the cuts from the other version, meaning that you don't have to cut the steering stops off your frame. No word on weather this is an option or the way the 848 kit will come.
The good: just like in the picture, the parts are gorgeous, very well machined and anodized. everything fit, and bolted right up. the 0 setting is 28mm, which is nice as Ducshop seems to be out of the triple clamp game. Offsets are +/- 1-3mm, marked and have really tight tolerances. THe stem needed a light sanding to pass the lower race cleanly; the lower bearing shoulder was properly sized and about a .001 interference fit-the oven and freezer method produced good results without resorting to a lot of hammering to get the race on. I like the locking rings on top to set bearing tension; but they could make them with more notches (than two) to ease tightening. The upper triple has a a bit of a gull wing to it; seems to be the same as the stock upper so numbers will carry over.
Assembling the triples was easy, IMA really goes in for lots of 5mm bolts- eleven on the lower alone- to tighten everything up; it does make for nice light parts, but be prepared to do a lot of tightening and use a torque wrench. On the plus side, these surely spread the load very evenly and should require less force to be tight.
The Bad: not much, all told. The steering stops work, but not for all offset positions. What they need to do is drill and tap more holes along the arc followed by the steering stop so you can space the eccentric stops somewhere useful- at 28mm offset, my clipons are my steering stops. Not really a big deal. The bearing support at the bottom of the stem is about 3mm thick-nice, but they didn't relieve the triple clamp to allow it to be flush with the top side of the bottom clamp. Again, no big deal, but this eliminates most of the need for the deep cuts in the lower. One potential PITA is the $70 shipping for kits that drop ship from Italy. THe kit is still a good deal compared to the Attack/nichols options but why have a US importer if you they aren't going to stock? No word on what IMA USA plans to keep on the shelves.
The Ugly: I think the steering damper mount could be improved, I am sure it's strong enough, but it could be more rigid and 3mm screws are a pain in the ass in an application that must be loctited. Its just CNC, right? make a little extension of the triple like everyone else does... I you have a GPR, it looks like the bracket could be milled out a few mm to fit over the stem and the nut seems to fit between the damper and bracket. It should fit, but might need a slot milled in the top clamp to locate the damper.
Service: aside from waiting months to find out anything at all, they were great. Josh had the kit out the next day and the receipt and tracking number to me the same day. He even included something called a goo-goo cluster (local candy) which was delicious.
Verdict: a solid option for the racer looking for nice parts and adjustability.
