1 - 3 of 3 Posts
Can/will you alter the ECU's fuel map to incorporate PC III remapping parameters if I send you the ECU and the PC III spreadsheet?
Can/will you defeat the clock-set / ECU matching requirement so that I can eliminate the clock-set?
Can/will you defeat the chipped-key requirement so that I can eliminate the keyed ignition switch on my track bike?
1 - 3 of 3 Posts
