1 - 2 of 2 Posts
Hi everybody,
My GT1000 won't start. The dashboard is flashing "LOAD". I've been told some is wrong with the security key speaking to the computer to let the bike start. Rather than replacing the whole system which would cost $4k, any ideas on how I could fix this? I don't care if I have to just disable it in some way.
Thanks!
My ‘07 Monster was would not crank. It turned out that the Luigi had put the zip ties too close to wiring connectors when zip tying the wiring harness to the frame. This cause the wires to pull out of the connectors just a little bit and cause bad connections. I cut all the zip ties, cleaned all the connections, and pushed them back together from both sides.
Never bypas doing a LOAD check on the battery, and cleaning all the grounds. I had a battery which checked as high as 13.1v after a charge, but failed a load test. Dash was going crazy, bike would not crank at all. I thought 13 volts meant good battery. Not True.
1 - 2 of 2 Posts
