My PS died promptly (no sputtering and then dying, just a very sudden/instant stop of the motor) yesterday right before I was about to get it into a parking spot on campus. At first I thought I had pushed my kick stand down or run out of gas or something stupid like that. Upon closer inspection (ie trying to start it up again), it would not start up again. The lights and dash are getting power and I can hear the fuel pump making its usual noises when I turn the key to 'on'. You can hear the motor turning but it will not start. Luckily, a friend of mine with a truck and a ramp wasn't too far away and we got it back to my apartment (I wouldn't want to leave a bicycle on campus over night, much less my PS). Today, I pulled a plug and pressed the ignition button just to see if it was actually getting a spark, and it is, so that's good; I guess (and hope) I can rule out the ignition system. I've read about the fuel line issue with these bikes, but am thinking it isn't that on account of the sudden failure rather than a sputtering, slow failure, however, I am not ruling that out. The bike has about 7400 miles on it and I would have expected the fuel line issue to have manifested earlier on in the bike's life, but perhaps that is a false assumption to make.
Any ideas as to what might be the problem? I did some research before posting, but only came up with fuel system issues. If it is a defective fuel system, isn't that covered by ducati even after the warranty period has expired?
Thanks in advance,
Josh
Thanks in advance,
Josh
