1 - 20 of 53 Posts
Old Wizard
Manufacturers' Recommendation
Most motorcycle manufacturers recommends motorcycle-specific oil, pointing out that car motor oils have been reformulated and no longer meet the needs of motorcycle engines. Oddly enough, they usually make no distinction between the use of synthetic or petroleum-based oils even though it's an established fact that synthetic oils are a better lubricant. Full synthetic oils offer truly significant advantages, due to their superior high temperature oxidation resistance, high film strength, very low tendency to form deposits, stable viscosity base, and low temperature flow characteristics as compared to traditional petroleum-based oils. Yada, yada, yada ...
They also make no distinction between petroleum and synthetic oil when recommending oil change schedules even though the oil manufacturers suggest that synthetics can be run two-to-three times the mileage of petroleum oils between changes. The oil drain interval that is specified in the owner's manual is for what is called normal service. Normal service is defined as the engine being at normal operating temperature, at highway speeds, and in a dust-free environment. Stop and go, city riding, trips of less than ten miles, or extreme heat or cold puts the oil change interval into the severe service category, which has a shorter recommended change interval. So, manufacturers are saying to change your oil even more often anyway because no motorcycle experiences only normal service conditions.
Consequently, longer drain intervals should not be used to balance out the higher cost of the synthetics. Synthetic oil can be considered cost-effective only if the potentially higher rebuild and repair costs associated with increased engine wear are factored in. There is no convincing evidence, so far, that synthetic oils lowers these costs in motorcycle engines.
Anti-Wear Additives
According to their manufacturers, motorcycle-specific oils are claimed to be formulated with additives that reduce engine wear. Specifically, they point to the use of zinc dialkyldithiophosphate (ZDDP) as the prime anti-wear additive used in all engine oils. ZDDP, however, contains phosphorous that has a life-shortening effect on the catalysts used in exhaust emission equipment, first only on cars, but now more recently on motorcycles. So the Environmental Protection Agency mandated a reduction (from a maximum of 0.12% down to 0.10%) of anti-wear additives containing phosphorous in automobile-specific engine oils.
It's important to note that this reduction was only required for the "energy conserving" lower oil viscosities of 0W-20 through 10W-30. The thicker oils were not required to meet this lowered phosphorus level. That is not to say that oil manufacturers won't lower the ZDDP levels in their 40 and 50 weight viscosity oils in the future. Since additives cost the oil companies money, if they feel that they can get by with less, they probably will be inclined to do so. Also, standardizing the additive packages across all viscosities would also simplify their production process. It's important to note here that, formulating oil with higher levels of anti-wear compounds than is needed, simply results in unnecessary combustion chamber deposits. Which is why most oil companies LOWERED anti-wear compound levels even before EPA required it.
So far however, tests have shown that automobile-specific Mobil 1 15W-50 (a viscosity exempted from the mandated reduction) has had no change in phosphorous level in its formulation. Further, Motorcycle Consumer News tests have shown that after the EPA-mandated reduction, Mobil 1 motorcycle-specific oil has now only about 15% more phosphorus than automobile-specific Mobil 1 15W-50 and about 6% more zinc.
Keep in mind however that, even though automobile oils now contain somewhat lower levels of ZDDP, Exxon-Mobil still states that Mobil 1 automobile oils "exceed the most-demanding protection requirements of modern, high-reving, powerful 4-stroke automobile engines ... yada, yada, yada." So, where's the reason to believe that the lubrication requirements of street motorcycles is measurably different? It seems clear that the current anti-wear additive levels in modern synthetics (both automotive and motorcycle blends) provide greater protection than required in any high performance motorcycle engine during the suggested oil change interval.
The oil manufacturer's advertising that directly equates reduction in engine wear with the tiny percent changes of ZDDP in the oil is misleading the consumer at best. It's well known that majority of engine wear is known to more likely occur during the metal-to-metal contact of a cold start, an operating condition best handled by a synthetic oil's very high film strength properties. Increasing the amount of ZDDP in the oil does no good if there's no oil coating there at startup.
Catalytic Converter Models
The latest models are now being shipped equipped with catalytic converters. Since motorcycle-specific oils with higher levels of phosphorus are now verboten by EPA for use in these models, I'm curious what oil the bike makers will now recommend? Maybe automobile-specific Mobil 1 15W-50.
Friction Modifiers
Exxon-Mobil claims, as a selling point, that the formulation of motorcycle-specific Mobil 1 MX4T has none (?) of the oil additives called friction modifiers (usually molybdenum-based but not necessarily) that could lead to clutch slippage in some wet-clutch motorcycles. This is not an concern, of course, for dry clutch models. But, this IS supposed to be the current compelling reason to avoid some automobile-specific formulations of Mobil 1 that now contain friction modifiers to meet fuel economy mandates, when previously they did not. At it turns out, wet-clutch slippage can be a problem, and seen more often when you use the lower viscosity 10W-30 Mobil 1 and other oils that are designated "Energy-Conserving" on the bottle. As a perspective on this issue, a Oct 2000 Motorcycle Consumer News test showed that the molybdenum content of Mobil 1 MX4T motorcycle-specific oil is 5 ppm and 11 ppm for Mobil 1 15W-50 automobile-specific oil.
Energy-Conserving Oils
Combine a lower viscosity oil with a formulation that includes additional quantities of molybdenum-based friction modifiers and you get the Energy-Conserving designation in the API Service label on the back of the container.
But, automobile-specific 15W-50 Mobil 1 doesn't carry this designation ... because of its higher viscosity. A higher viscosity oil's resistance to flow is the reason why automobile-specific oils that are not energy conserving have been used successfully in wet-clutch motorcycles without slippage problems. So 15W-50 Mobil 1 works fine in wet clutches. Keep in mind however, that because motor oils loose 30% (or more) of their viscosity in the first 1,500 miles, you will tend toward wet-clutch slippage later if you prolong your oil change interval.
Viscosity Retention
A frequent marketing claim made for motorcycle-specific oils is that they retain their viscosity longer than automotive oils when used in a motorcycle. That is, motorcycle-specific oils contain large amounts of expensive, shear-stable polymers that better resist the punishment put on the oil by the motorcycle's transmission, thus retaining their viscosity longer and better than automotive oils would under the same conditions.
Nevertheless, when tested by MCN, the best-performing oil of the group tested was Mobil 1 automotive oil. Based on their test results, here's their advice:
1. Use a synthetic oil. The viscosity of synthetic-based oils generally drops more slowly than that of petroleum-based oils in the same application. There is no evidence that motorcycle-specific synthetics out-perform their automotive counterparts in viscosity retention when used in a motorcycle.
2. Change your oil more frequently, and more often than 3,000 mile intervals that is normal for cars. Motorcycles are somewhat harder on an oil's viscosity retention properties than cars. (The gears in the transmission are probably the significant factor in cutting the longer oil molecules into shorter pieces that are less viscous.)
3. Use the Mobil 1 in the 15W-50 viscosity only. The recent reformulation of thinner viscosity versions of Mobil 1 make them inappropriate for both wet and dry clutch applications.
Better Detergent Additives
Exxon-Mobil claims, also as a selling point, that Mobil 1 MX4T is specifically designed for sport bike needs and therefore uses a different dispersant/detergent technology for "better high-temperature performance and engine cleanliness." Without an explanation of this technology it's hard to be specific here but one thing is certain. Water-cooled motorcycles operate at similar temperatures as cars do so this presents no obvious advantage here. The dispersant/detergent issue is probably more directed at wet-clutch designs where abrasive friction material particles are suspended in the engine lubricating oil, so there's no distinct advantage to dry-clutch motorcycles. Changing your oil frequently negates this issue.
Marketing
Separating the oil manufacturers' marketing hype from fact is difficult for the consumer. Given that the role of marketing is to enhance their oil's image and persuade you to switch to it, be sceptical when presented with unsupported claims.
A tactic often taken is: more is better. In this case, if the higher levels of anti-wear compounds advertised in motorcycle specific oils are good, still more is better, right? Maybe, but using oil with higher levels of anti-wear compounds - than needed - will cause increased combustion chamber deposits. That is why most oil companies LOWERED anti-wear levels before the government mandates intended to protect catalytic converters.
Another approach, enhancing their product's status through premium pricing and sponsorships (that are essentially paid endorsements) are effective ways of positioning their product to convince you, the consumer, that you're getting the very best when you buy it.
If you're not a product engineer, guidance from sources like Consumer Reports can be useful here in making informed decisions. For example, they did a quality comparison of several products a few years back and found that the less expensive products often worked the best and had the highest quality, but noted that people tended to buy the more expensive products because they thought they would be better.
Keep in mind that your dealer's will first recommend what they sell, and it's natural to expect that they'll try to sell products with the highest profit margin, all other things being equal.
Bottom Line
The bottom line here is, to get the best protection, you need to change any oil frequently. Changing your oil serves to remove abrasive dust ingested from the air, from (wet) clutch wear and harmful combustion by-products from the engine that accelerate wear. Studies have shown that most motor oils loose 30% of their viscosity in the first 1,500 miles.
So for the best motorcycle engine protection, dry clutch or wet clutch, I recommend (and use) the less expensive 15W-50 weight (remember ONLY 15W-50) automobile-specific Mobil 1 and change it every 1,500 to 2,000 miles.
Case well presented. You know how some people get top poster titles while filling this forum with unchecked info? You, Shazaam, are the other side of that coin. Thank you for sharing all the info you have provided to date, and I'm sure I speak for everyone else here, we look forward to reading much more.
+1. A really well thought out and researched post. Thanks for taking the trouble to do it.
The key point is to change your oil regularly. Oil "discussions" are really polarizing topics these days.
I have used Mobile 1 "redcap" and now 15-50 for over 15 years. My track bike spends all day at 8 grand, and never skips a beat. We all know deep down inside that the key difference between bike oils and car oils is the extra $4 per qt!
Anti shear and anti foam
Since Ducai engine share oil with the Transmission, one needs shear stable additives and anti-foam additives, which Motorcycle oil contains.
Car oil made for the engine not to be used in manual transmission.
I disagree, Honda cars for years used regular 10W30 in their manual transmissions, recommended by manufacturer, they last 200+K miles.
I have dyno tested Mobil1 against mineral oil (long story, but we drained and filled oil on the dyno trying to reduce clutch slippage) contrary to common belief about synthetic oils making clutch slip, we got higher RPM and power reading (less clutch slip) with automobile specific Mobil1. Now I use their motorcycle oil if I can find it
Mobil 1 Racing 4T 10W-40
if not regular 10W40 (only available in high mileage flavor)
valvoline 20w-50 racing oil in my bike
I did read your post Shazzam about the mobile car oil and im not sure that i fully understand if it's ok. I put 3 qts of Valvoline 20w-50 racing oil (fully synthetic) in my 2002 ducati monster 620 (wet clutch). After i put the oil in i began to think this might be bad. What do you think? Thanks!
did my first oil change since i bought the bike on my 03 999.the motor case says use shell syn 4.i looked all over for shell syn 4 with no results.i call the ducati dealer and ask him where to get that oil.he says no problem if you live in italy,but they do not sell it in the states.i ask him what he recomends for oil and he said mobil 1 15-50.i used that oil in my 2000 harley and it ran cooler and gas mileage went up.will see how it runs in the ducati.
Even Mobil doesn't say there's a difference
This is from Mobil's own website. You'll notice that they never actually mention anything different about the V-Twin motor oil being different in formulation than passenger car oil.
What about Mobil 1 V-Twin 20W-50 motor oil? How is that different from Mobil 1 for passenger cars?
Mobil 1 V-Twin 20W-50 fully synthetic motor oil is designed for air-cooled, large-displacement bikes. Because of their design, these engines can generate very high localized oil temperatures and high overall bulk-oil temperatures.
As you know, a typical air-cooled V-twin's rear cylinder gets a lot hotter than the front cylinder – it's a matter of airflow. When it's hot out and you're stuck in traffic, the oil temperature in your bike climbs rapidly. Above about 250°F, conventional motor oil is going to break down. Mobil 1 V-Twin 20W-50 fully synthetic motor oil is good to above 300°F.
Like Mobil 1 Racing 4T 10W-40, Mobil 1 V-Twin has high levels of phosphorus/zinc and the same high-temperature detergent technology for superior wear protection and engine cleanliness, even at elevated oil temperatures.
With Mobil 1 V-Twin oil, you can go the full length of the manufacturer's recommended oil change intervals with ease.
I used the Mobil 1 15w50 full synthetic automobile oil in my track bike- changing the oil and filter after every third track day- and so far I've replaced 6 flaking rockers. There is no way of knowing if the story would be any different if I had used motorcycle specific oil so take it with a grain of salt...
Anti-Wear Additives
Friction Modifiers
Viscosity Retention
Marketing
Bottom Line
thanks Shazaam for this information ...
Harleys have three separate oil requiring systems; primary, transmission and engine. Eventhough there is much discussion regarding which oils to use, there are specific oils for each. However, its also common for riders to use one oil for all three and as long as the bike runs good, its OK to do that. Seems Amsoil is the survey favorite for all three holes.
Great post... many thanks for all the great info.
To complement the Rotella T5 in 15W-40 I'll use in fall/winter/spring, I'm looking to pick some of this up for summer use in my '13 Multi, and it's currently $25.47 in the 5qt jugs at Wally World.
Has anyone seen it much cheaper than this? Two or more jugs also gets me free shipping, as much fun otherwise as it is to people watch there...
EDIT: There's currently a $12 off 5qt rebate via Mobil, bringing the 5qt jug down to $13.47 each!
I'll have to get some UOA's of my various lube deal flavors for the good of the people!
If your bike has a wet clutch make sure that the oil is wet clutch compatible. MA1 OR MA2 RATING
Regular car oil has fiction modifier, witch will cause the clutch to slip after prolong use.
1 - 20 of 53 Posts
