I had a fit-up issue as well with the Termi mid pipe and my 2004 749s. In the end I had to take the pipe to an exhaust shop and have it cut and rewelded to fit. Cost about $100.
I believe it has something to do with how some bikes have a low oil sump and some dont that causes this discrepancy.
thanks
I bought a used kit that " fits " but the difference is obvious . I would trade someone with the proper pipe...
The reweld idea is a good one , but is the midpipe titanium ?
Got your PM... The pipe is definitely stainless, so welding would be no problem. Are you sure you got the system for the MY05+ models (boxed swingarm, not cast) The exhaust for the cast swingarm ('03-04) will not clear the boxed swingarm. I had a very tight fit on my full system, and had to grind the welds inside the muffler joints to get my mid-pipe to fit properly. You can try mock-fitting the system, leaving all the joints/mounting points loose to see if you can pursuade the pipe to fit correctly. Another solution would be to just remove the catalyst from your stock mid-pipe either by cutting/rewelding or by breaking it up the element (which I imagine would be quite a chore).
Pics of the contact areas would help too.
Best regards,
Matt
original header is the same for all the swingarms, but differs due to the two sump configuration. the termi '03 - '04 header pipe won't fit a later swingarm, as the bend is much closer to the swingarm than the std header. can't really tell just by looking tho.
