Hi, guys... just bought the Termignoni manifolds for my Hyper and looking forward to install it in the next few days... the only thing is that I am not that familiar with technical stuff, so can anyone help me out a bit by means of advice? I mean is there something I should do first or be carefull with something when getting rid of the oem pipes and installing the Termis?
Also, I am thinking of drilling the hole in the airbox as well and the question is whether I can get to all the bolts holding the airbox without removing the tank. I ve seen a few bolts around the tank but which of those do I have to remove... all of them or just the 2 in front...? What about the cables around the tank... do I leave them as they are or I would have to remove something?
What about the servo motor... how do I remove it or I can just leave it as it is?
And the last question, after I changed the manifolds, installed new DP ECU and reset the TPS will I have to correct the throttle bodies? Or it isnt necessary?
Will appreciate any advice or comment. Thanks in advance.
