1 - 2 of 2 Posts
I have the termi 2-1 and velocity stacks kit on the bike (that way when I bought it) but no PC III. It runs good, but I don’t have anything to compare it to. My question is; with this setup is the fuel mixture too lean and can I harm the bike? The PCIII is on my list to get, but it is low on the list. Should I move it up?
Thanks,
-Chris
The race ecu included with the Termi exhaust is designed to be used with the included air box lid which doesn't flow as much air as your stacks. My guess is that you are running a little lean. If you are concerned, I would keep an eye on your exhaust tip and spark plugs. A medium to dark tan indicates you should be fine but if it looks white then you may want to do something sooner. You may also want to consider the PC V instead of the PCIII. I don't have a PC but understand it is a better unit and doesn't cost that much more. Be safe.
1 - 2 of 2 Posts
