Hey all, new to this forum, with a 2-1 install question.
Bought a used 2008 HM in Sept, that the PO had installed a 2-1-2 Termi slip on, with the stock header. I just bought, and installed the full 2-1 system(PM me if anyone is interested in buying the 2-1-2 slip on). The lambda sensor was missing from his work, the hole in the header near the cat was plugged, plus the electric connection capped off, too. Is this also the way to set up the 2-1 system???
i.e. No lambda probe, hole in header plugged with threaded insert, electrical connection capped off ???
I have also found several comments regarding a TPS re-set. My plan is to finish this install, ride it to the shop in Reno, and have them do the TPS - should be a minimum shop charge, I suppose.
Any suggestions about the TPS part of this system??
