Seen a lot of ppl post about this, minus the work involved on some models I heard great raves about doing tapered rollers instead of balls. It should take out some slop in the steering head.
When I fitted the lower race bearing on my 916 I put the stem into the freezer for a few hours and warmed the bearing and it literally dropped into place.you'll need a soft hammer & a piece of pipe slightly bigger than the steering head tube to press the lower race on, it can only touch the inner lip of the race though so a nice sliding fit. i got a nice piece of stainless from a custom exhaust maker.
+1 works a treat!When I fitted the lower race bearing on my 916 I put the stem into the freezer for a few hours and warmed the bearing and it literally dropped into place.
Also with the removable steering tube, fitting the outer race was much easier than a conventional steering head as everything is more accesible on the bench and the tube can go in the oven to heat it up before pushing the frozen race into it.
Definitely the easiest head bearing swap I've ever done.
Yes, but not from ebay. Was reasonably easy to do. Bearings went in freezer. All went well. Could tell difference, possibly because the bearings I was replacing were on their way out and yes they had been inspected, cleaned and greased when servicing demanded it.Did anybody tried tapered steering bearings? I saw then in Ebay and they cost (a set plus dust covers) 2x less then the OEM bearing set. Are they better then round bearings? And you feel any differences?
Thanks!
