I need to take off the front headlight and lift up the tank to hide some wires. Is this in the owners manual? At least to lift the tank up? i hate just blindly guessing.
well I only got the rider seat off before the wife showed up and the party was over. Gilly, I suppose you ran these lines from the dash? did you take the air box covers off to access the lines already from the dash. if i don't have to lift the tank that would be best.i ran multiple cables when i installed the data logger and smartycam. one useful technique is using zip ties to fish wiring. start from the front and tickle it with the zip tie and electrical tape to the back of the bike. i never had to take the tank off foe cable runs.
Its a burns moto USB charger, searched the web and it looks cleanest. im going to try and hide it behind the light and between the handle bars. And I'm using a ram mount also. speed tested up to 120.That's a clean looking USB charger.
Not sure what mount you are using but these RAM mounts seems pretty good and I've not lost my phone yet. Quick disconnect so I can mount my GPS if going into the nether regions.
Good, that's thats the advice I've been looking for. But I was getting kind of jazzed up about going deep, next timeI ran the wiring for my radar detector from under the seat to the handlebars. All I did was zip tie to the wiring loom that runs up the left side of the frame to the headlight and then follow the cables to the left bar. The only parts I had to remove were the fuel tank side panel and the air box cover. No need to remove the tank or headlight if you don't want to.
If I recall, yes, pulled only the right side off just to make sure it was a neatly threaded wire. Trcky tight part was feeding up area of the steering stem tube to behind the dash. Just remember to chk bar to bar play if you run anything to the h-bar.well I only got the rider seat off before the wife showed up and the party was over. Gilly, I suppose you ran these lines from the dash? did you take the air box covers off to access the lines already from the dash. if i don't have to lift the tank that would be best.
