1 - 15 of 15 Posts
I need a little advice. A piece of black synethic material came into contact with with my hot exhaust pipe on my hyper 950sp. Fortunately only a small bit of it burned onto the exhaust. However, I’m not sure the best way to clean it without harming the finish on the exhaust. I attempted to use a paper towel with some rubbing alcohol, but that did nothing. Before I try a bunch of things, I figured I would seek the guidance of those much wiser than I.
Pic below:
Although I've never tried it, I've often heard Easy-Off works well for that kind of thing. Personally, I'd probably try mineral spirits, lacquer thinner or brake cleaner because I have it on my shelf. Let's see what others suggest..
Old Fast Guy
If you try to scrub it off, it will leave a different shaded surface. It's so small, I would just let it turn into carbon and come off by itself. A few WOT trips through the gears will get it hot enough to start the process!
Brake parts cleaner is a favorite of mine when it comes to getting nasty things clean.
'02 ST4S
Dolemite , since you saved all your $$$ by not attending various riding events this year, I would suggest it's time for that new full Termi system you've been lusting for! One of us can send a note to the wife explaining the ruined exhaust system and need to console your mental anguish where only a full system will suffice...easy peazy!!!
Super Moderator
Melted on plastic. That's a tough one. As was already mentioned...no abrasives. I would be tempted to use a plastic scraper (I really like the red ones that look like razor blades!) to see if the stuff can flake off. I too would go for the brake cleaner first. Try it on portion of exhaust that's not visible...just in case!
Discussion Starter #9
Oh wow, many good recommendations. Some better than others...ahem... @flynnmon .
So far I like the idea of seeing what happens after a few heat cycles. If it doesn’t start to sort itself out, then I will have to try one of the many other ideas.
If anyone has any other ideas, keep them rolling!
It's a neat pattern though...you may want to wrap more of the fabric around the pipe to continue the process. Almost looks like carbon fiber weave. 😉
Just stencil out "DUCATI", heat the pipes up, and rub an old boot over it....lol
Come in Spinner :)
Acetone should shift it, but first try out on a non visible patch of the can to see it it marks it.
I've had this happen before to the hot exhaust of my dirt bike ...gym shorts got too close and melted a hole right through my shorts, left a patch of synthetic material on the header pipe. I had already ceramic coated that header but after the brush up, it left a pretty bad spot. I ended up having that pipe re-coated because nothing else would take it off. Looks brand new now.
1 - 15 of 15 Posts
