Help!! I need a number!
I just replaced the ball bearings in the 998 swingarm, but because of the sleeve between the bearings I cannot tell if the bearings are fully home. The inner spacer still has about 1/8" of lateral play between the bearings.
Can someone give me an accurate measurement of the width measurement across these bearings? A machinists rule, or depth gauge end of a caliper, inserted through the shaft bores would be a good way to measure.
Thanks!
BTW it is the ball bearing side (6005) that I need, not the needle bearing side.
Thanks!
