Anyone here using a SW Motech on their DVT? If so, which one are you using? Want to order one but want to make sure it will work.
Thanks.
SW-MOTECH Quick-Lock EVO City. But it will block your GPS unless you use an elevated mount like the Ducati Navihalter.
Resident Raggamuffin
I have one (small, not sure the exact size) and the only negative is that it makes it hard to reach the turn on switch at the front if the tank. Of course it can be removed before doing so.
