1 - 16 of 16 Posts
2019 1260S Volcano Grey
More specifically, does the lever arm hit your heel, or did they design it short enough to avoid this problem.
no complaints
I have one and I haven't noticed a problem, but I wear size 8 boots....
I'm size 11 boots....no problem.....
Lots less money than Ducati part.
Search the forum for "Slotting the belly pan.....makes oil changes so much easier when you have the centerstand....
Northlight
Resident Raggamuffin
size 10 boot....great improvement from stock but i can still feel it "if i try to." ....super customer service....
Size 10's here too, never felt the SWM center stand. Perfect! :cool:
-SM
Any pictures of the SWM ?
Discussion Starter #8
Thanks for the feedback gang. I'll order it now. To bad the PP doesn't come w/ a center stand (which I would have to cut down anyway).
I've been toying with the idea of buying this SW Motech center stand, but I just bought one of these gizmos on ebay and I'm wondering if it might be an acceptable substitute for a centerstand: Hardline Products - Rollastand® for Sportbikes
The only drawback I can think of to this solution over the centerstand is that you can't take the wheel off the bike. But, in order to get the wheel off in the wilderness by myself I'd need a breaker bar and socket, which I ain't hauling around anyway. So, even with a centerstand, that would be a job to have done in a local shop. I have a Pit Bull rear stand for wheel removal at home.
own one....not a replacement for a centerstand whatsoever. it does aid in cleaning either wheel if the bike doesn't have one. nifty but not great.
anyone currently employing a SW Motech center stand on their Multistradas? not one that was customized by them (originally offered as a service), but an actual stand that they design and sell today. mine doesn't "snap back" into place when removing the bike from the center stand....do yours?
thanks in advance,
I have a standard SW Motech stand with no mods. Purchased it September 2013, no issues to report.
thank you.....i can't see anything else being the culprit other than the spring(s)...but a sagging/not-taught center stand i definitely don't need.
I've had one on my bike since last October. No issues, no interference with my size 13 feet. It snaps right up when I roll the bike off it. Super easy to get on it too.
I have the standard SW Motech main stand on my bike
No issues with size 9 UK boots
But I did have an issue with the crossbar of the main stand resting on the de-cat pipe of the ARROW exhaust system, I had to make my own stopper, used an stainless 8mm bolt, washers and two 8mm stainless nuts to space it 6mm away from the de-cat exhaust pipe
1 - 16 of 16 Posts
