Well, after reading several topics here on suspension setup, decided to give my local ducati garage a call, and have their mechanic setup the bike correctly for me.
As the hyper(std) is my first bike, did not want to get ahead of myself, and change everything before I got used to it.
I am 220lbs, no gear. Mostly riding some of the nicest mountain passes in the world, here in switzerland
The issues I had, were mainly the rear wheel skipping about occasionally when hitting a corner hard (and the surface was not perfectly smooth). Also, seemed to bottom out the forks once or twice.
So, he increased the preload both sides. Said that when in a corner, the rear was fully compressed, and I had no more play left, hence the wheel jumping. I also think he slowed down the rebound a little. He had me sit on the bike, checked the sag was good....checked that the compression, rebound looked even, then too it for a quick test ride (he is the same weight as me).
He said all was perfect, apart from the forks. He still managed to bottom out a couple of times under hard braking. The advice was that I could do with more progressive springs, so a set has been ordered pending my own test ride yesterday.
So, onto ride post-tune - wow
Went with some friends, and rode the Susten, Grimsel, Furka and Oberalp passes, (oberalp twice!!). If you have not heard of these passes, google them, and prepare to drool!!!. Spent over 8hrs on the bike - and amazingly only got a little sore and cramped in the last hr!!
I did not feel the rear skip out once, felt I could hit corners a LOT harder, and the bike felt like it was on rails. I realise now it felt a little "vague" before. The whole thing feels absolutely planted. Almost like a new bike!
The only thing I did not replicate was bottoming out the front forks. But then I am still not riding too hard. So, do you think I should still spend the money and have the fork springs replaced? I trust my mechanic, and sure when riding harder it will help, but wondering if anyone else my weight has done this and found an improvement?
Thanks all for the suspension threads, and advice to get it setup!
