1741 - 1760 of 3797 Posts
Hi,
Hello,
This is my 800 SS after the change the only ones ugly parts IMHO that has the SS ie. The next that I would like is the Sargent seat and the radial master cyl but I don´t know when ...
Regards
You have replaced the original tank pad/protection with some kind of carbon fibre part? How you have done this?
Nice Monty. Pic of MGA too please. Nice to see another MG / Ducati guy - I've got 2 BGT's and a '92 900SS :D
im not sure if this is against the rules but since you asked, taken at a local vineyard. 1961 mark II, much like a 900ss it will never be the fastest but it handles like a dream and just "feels" right....
he has bought the carbon tank pad here:
http://www.mblscarbon.com/engine/shop/index.html
the quality is alright, the weave pattern is a little coarser as with the
ducati performance carbon parts, but for that price one can't complain
anyways.
cheers
Does this come with similar "3M double-sided tape" as the original pad ?
Are the original (grey) tank pads available somewhere or is there other options for replacing worn pad ?
My bikes:
My bikes:
Yes it comes with double side tape but in my case I can´t make it works, after 3 times with diferent tapes I try with sikaflex and now it´s fixed.
Regards.
Australian 750ss 2002
Mods
Staintune Pipes
BMC Air Filter
K&N Oil Breather
Carbon Fibre tank protector
Ducati Performance mono seat
Tinted Screen
Classic Decals
Tasty! Where did you get the oil cooler cover? Or is it custom?
Maybe it's looks different due to the sun but it's a standard Ducati oilcooler.
I don't know from what year because when I bought this bike engine was completly damaged and I rebuild it myself so I also had to find a new Oilcooler .
While I was doing this I thought , what the hell I do the rest also.
So it took me 1,5 years instead of 2 month :crazy:
Wilco
MWR are the tubes a ram air system under the front of the fairing
Hi Dude,
A kind of , a ram-air system is when the tubes are connected with a closed airbox .
I cut mine off
I placed a filter on the carbs and he wouldn't rev above 7500 RPM anymore.
I found out that when you ride the bike , you create a vacuum behind the fiaring and under the fuell tank.
You can find out for yourself , at one point of speed your key ring of your ignition key will bend over to the front in direction of your tacho
(I hope you understand what I mean)
So I made these plate and tubes to guide air to the filter ,and it helps (a lot :D)
Wilco
Hi Dude,
I cut mine off
Wilco
thanks for the explanation I thought the tubes were hooked the a sealed air box
Hi Dude,
I cut mine off
Wilco
Hey Wilco,
sounds good......
Would you have any pics of it with the tank up and airbox removed to better see how you did it ? I know it would be ( fairly ) simple, but if you got pics I can cheat !!!
Cheers,
Darryl.
Hey Wilco,
sounds good......
Cheers,
Darryl.
Hi Darryl
Yeah no problem , I hope I can make some pics tomorrow , it's so bad weather here and to make good pics I have to take the bike outside
I will show you how you can rev a 900 ss engine up to 10000 RPM with no Carrillo's , racecams , lightweight parts and with the stock carbs :D :D
Wilco
I would like to share some pics of my 1992 900 SL #123 from Belgium
Hey, you've got a great looking Superlight! What exhaust do you have on? It doesn't seem to have a balancer pipe linking the main header from the front cylinder with the header from the rear one, basically two individual pipes which is quite unique.
Correct , the mufflers are std. 888 SP4 . They look great on the bike (I think ) and a friend of mine fitted the mufflers to the std pipes
He says that when you make a good exhaust you don't need balancer pipes.
He makes exhaustspipes for the factory teams of HVA and Husaberg Supermoto so I don't contradict him and let him do the job.
The sound is so different now , It's more between the 888 and the old F1.
When the wind is in the right direction , my wife hears me coming at around 3 miles :D :D.
Wilco
