21 - 36 of 36 Posts
Discussion Starter #21
what rocker weight do you work to and how do you distribute it calculation wise for balance?
That's a good question !!!!
Very difficult to have good information
Some say to go on 108% of the piston before, other 70% ....
Discussion Starter #23
Off course, I design the rocker according to that
Discussion Starter #25
This engine is just for fun and it's more fun to make a rocker (from my point of view) :giggle:
The last rocket Design :
975523
Weight : 360gr
Weight at mid stroke on the rod axle withe pin : between 350.5gr (solid pin) and 270gr (drilled pin), not so bad
And I can still lighten the rocker if needed
Wow! So much time and money to make a slower bike ! A Ducati version of a Buell Blast.
Discussion Starter #29
Thanks @highflyer
Impossible to see the yahoogroups discution, I'm a member of the group however
I will start a discussion by email
Discussion Starter #30
Some news :
And a video :
Looks good, Samuel.(y)
Managed to find some time to debug my code.
Below are some graphs from testing it with 1m long rocker, and moment of inertia equivalent to (piston + upper rod) mass, at the 1m radius.
The forces are what the main bearings experience.
If you want to see how your set-up behaves, send me the measurements of your upper con-rod and complete piston masses along with the moment of inertia of the rocker from the CAD drawing.
Regards
Angelo
979621
979622
Discussion Starter #32
Work in progress :
Discussion Starter #33
Engine in the 848 frame !
749 Dark fork OK
But not the 748 tank with the 1198 airbox :cry:
Rocker oil circuit OK
For the moment 999 rear swingarm
I search a water radiator smaller than that of 748 (which is twisted ...), Do you have any ideas?
If you keep the rear piston for balancing, I assume you run it with no rings ? That would seem like a lot of friction from the piston. Has anyone tried Teflon buttons in the skirt to reduce friction ? Has anyone tried a reed valve in the “head” to release pressure ? Those holes in the piston affect balance weight but don’t appear to be enough to eliminate all pressure. The rod big end could be made heavier to keep the engine balanced.
Discussion Starter #35
You shouldn't have read everything I wrote ...
Discussion Starter #36
One ring on the rear piston for good guidance
But I never did this montage
21 - 36 of 36 Posts
