Well got it about as unfooked as I could today. The guy I got it from said that the bike wouldn't run because it "didn't have any spark". Pretty much every bit of wiring has been touched by the knuckleheaded PO and will either need to be repaired or just straight up replaced. I managed to get the oil drained and stripped it down as you see it. I was surprised to not see any horrible metal particles in the oil. Of course the speedo cable inner is missing so I will assume quite a few more miles were put on it after it broke as this did not look like a 1000 mile oil change. Also pulled apart the tank to drain the fuel and of course the old water. There is some rust in the bottom of the tank, but it does not look as if it's weakened the steel. The tank has a number of dents that will have to be pulled, so it will need to be repainted, so boiling it out at the rad shop may be necessary. Anyway, don't know what more I will do beyond this at the moment as I have a Harley WLA, 92 GSXR 6/11 build going and a M3 halftrack ahead of it.
