21 - 27 of 27 Posts
I have now bought cables so that I can run MelcoDiag and pull error codes from the bike; it was a rather expensive trip to the dealer for diagnostics -- although cheaper than my car -- but at least it identified the problem on my bike.
I am diagnosing similar issues with my 2012 MTS 1200. Can you kindly share what cables you purchased that worked with MelcoDiag?
Thanks in advance!
Mine never threw a code either and I have had two occasions of similar behaviour. The local dealer tells me it should throw a code but it never has.
The first time it was an air leak from the injector seal and I too tried the remove a MAP sensor trick to try to diagnose. The second time it was the horizontal MAP sensor but I presumed it was the injector seal coming back and just took it to a dealer who were able to read the MAP values as being out of spec.
21 - 27 of 27 Posts
