Have had my Black SFS for 3 months now and have put around 7300 Kilometers mostly on twisty roads and very few around town. Something on the bars did not fit me , bars seemed quite narrow as well as putting my wrists into an awkward position. The result was that after an hour and a half on the twisties my hands would go to sleep and I woud have to stop before i couldn t move them the way i should for my riding. Two weeks ago i bought a DP S4RS bars and fitted it on the bike. The bars are EXACTLY the same as far as bends go compared to the SF bars but are 75.1 cm wide as opposed to 72 cm of the standard SF bars.
Four days ago i received another order i had for RENTHAL fatbars which i fitted. These are RENTHAL 814-01 Streetfighter bend Tanium colored. These bars are 76.9 cm wide . I fitted these also and went for a short 100 Km ride at the twisties as well as a rather long 600 Km half freeway ,half twisties trip.
I took some pictures comparing and i ll add some comments at the end. It may help people to decide what they need.
DP S4RS fatbars installed
RENTHAL 814-01 installed
TOP is RENTHAL 814-01 BOTTOM is Standard SF bars 1
TOP is RENTHAL 814-01 BOTTOM is Standard SF bars 2
First of all the DP bars have what it seems to be missing for reasonably wide shoulders. 1 1/2 cm more width each side seems to decramp forearms and wrists. DP bars are still kind of low but in my opinion contribute well to the aggressive bike-hugging stance that is needed for riding of the SF. And when you want or need to go really fast and have to lay low on the tank your arms are not uncomfortable. Turn in is quite easier than the Standard SF bars but sensitivity and precision is not lost. One more thing. The DP bars have drilled holes for the switches and throttle but do not coincide with the SF ones , not even close. So what i did was to lose the little plastic thingies on the switches and throttle housing and I can move and fine tune the inclination of the bars , levers and switches to my taste.
Second , the RENTHALS. These bars are almost 2.5 cm wider each side than the standard SF bars. Their measurements can be seen at:
http://www.renthal.com/File/product...one=&biketype=&manufacturer=&model=&bikedate=
Their bend are slightly different than the 604-01 that Hedetrimmer has been using. 2 cm less wide overall and with a quite narrower center section.Almost same rise and height and a little bit more sweep.
These bars feel a lot more comfortable. You can sit more upright and leverage is way more on these. You can also tuck down flat on the tank for high speeds but then your arms are kind of folded , not so comfortable. Turn in is a lot easier than the standard or DP bars , at first a little bit too easy but easy to get used to. Tank clearance for the switches and levers is a lot bigger and you can try the bars in a variety of different inclinations to suit your style .
Overall i liked the RENTHALS. Took some time to get used to the extra leverage but my 600 Km trip was easier on my body and wrists compared to the standard or DP bars. I would say that if it was 2 cm less wide (same as the DP bar) it would be a lot better but i dont think it has the margin to be trimmed . Turn in was a little too easy and precision and sensitivity is a bit compromised.
On a final note , i ll keep the RENTHALS for some more days but i think the DP bars kept me a little more satisfied than the RENTHALS. Not perfect but gave me most of what was missing for the standard bars.
